probably going to have to make something work. its not that complicated a system, you might look at the holley kit and see if you can make it work on the qjet with a little massage.
I thought about that, but wasn't sure if it'd work or not. I found a universal one a while back, but of course can't find it now... seems as though some of the q-jets came with a TPS on them, but kine doesn't have one.
That is the route I took with a truck avenger. Used the end of a Lokar C4 kick down cable. Its been working great for a year now. Only stuck open once on New Years day. I had to swap the first one the ohm numbers weren't correct. The swap at the parts store was no problem.
Give the guys at Bauman a call. They are more than helpful and just came out with a direct fit to for edelbrock carbs so they may have something in the works or would know where to point to.
