kholding
I am about to run my 4r70w cooler lines and wonder if most out there using this transmission are using a separate cooler? I have the Champion aluminum radiator with tranny cooler but not sure if I should get an auxiliary cooler? Also, is it OK to use steel braided line instead of hardline between the radiator and transmission? I live in Las Vegas so this will see some higher temperatures. Thanks in advance.
