- Nov 28, 2001
- 10,302
I'm trying to install Explorer 5.0 fuel rails on my '91 5.0 that still uses the TFI distributor. I'm running into a problem where the driver's side rail makes contact with the back of the distributor body, which doesn't allow the tabs on the rail to line up with the attachment points on the manifold. I could probably slot the rail holes a bit but I'm afraid the misalignment of the rail to the manifold could cause problems/leaks with the injectors/seals.
Has anyone else run into this problem? If so, were you able to resolve it?
Thanks,
Todd Z.
Thanks,
Todd Z.
