smoked77
Just need some help thinking through my logic.....
A 5.0L HO mustang cam should work in a 5.8L right? Both are the same firing order, I am using a mustang harness and ECM...
The cam is driven off the crank, so the valve events will be driven by the crank. Basically, it should act like a bigger 5.0L.
The 5.8L is the same bore as a 5.0L, so the cam should fit. The only difference is the stroke.
Am I missing something?
