easton68
I am installing EFI on a 5.8. I have the lower intake and fuel rail bolted on, the stock throttle linkage on the firewall is hitting the fuel pressure regulator. my gas pedal is stuck wide open. Has anyone had this problem? Does anyone have suggestions onhow to fix it? Also, what should I use for the throttle cable?
Thank you
Easton68
Thank you
Easton68
