kiteoregon
- Nov 21, 2011
- 292
I have a 68 sport and believe it's the 6 cylinder 289. The current carburetor is a small little guy that is seen some hard years, it's time to replace. Knowing that some day i will upgrade the motor i need a short term / med term solution. What carburetor options should i be looking at? This will be my daily driver 20 miles each way to work, on the weekends it could be towing, off road, or at the beach / sand dunes. Probably nothing super crazy as it's mostly stock with a 3.5" lift. If it matters, i have the 3-speed transmission, but the 4 Speed AOD is in the mail.
Do i just do a stock replacement? Upgrade to a 4 barrel, qudrajet etc. Not trying to spend a fortune. I will also be installing a carter electric fuel pump at the same time.
KiteOregon
KiteOregon
