'68 LUBE: Help with Suspension Lift, Body Lift, Tire Size
Putting new axles in this weekend. (Dana 44 & 9" from a '77 Bronco) and have to buy suspension kit.
Do I go stock or 2.5" lift? (picking kit up at WH)
Current tires 235\75\15 (I will keep rims & hub caps, but when these tires wear out replace with 31" tires)
Here are my pics. Stock, and then added 2" body lift (so we could fit the 5.0 and 6R80)
dto_garage.php
pics are in "my garage"
I really like Bronco77 blue bronco look:
viewtopic.php
Im having issues getting pics posted
Batgirl89
Ok Im having computer problems. Operator error. And typos! :-[
Putting new axles in this weekend (Dana 44 & 9" from 77 Bronco) and have to buy suspension kit.
Do I go stock or 2.5" lift? (picking up from WH)
I have a 2" body lift (for the 5.0/6R80)
Current tires 235/75/15 (I will keep rims & hub caps, but when these tires wear out replace with 31" tires)
pics in my garage of stock, then we add 2" body lift
I really like Bronco77, Blue bronco look. (cant get pic to post)
904Bronco
San Martin, CA
Just answered your question on NorCalBroncos...
2.5" lift, 1 " body Lift, 31" BFG's on 15x7 rims.
Added a 1" block on the rear as the Springs began to sag with Hardtop weight.
Too late to return for warranty, so added a 1" block. Not my 1st choice, but
it worked.
BY THE WAY My 68 was purchased by DirtDonk, so you may see it popping up here on the site :)
Batgirl89
it worked.
Thank you so much for the info and pic. Its perfect!:)
1971lubr
Cape Coral, FL
Search the various lubr threads on here for all the pictures and information you need. .
My personal thoughts on lift tire combinations that look & perform best are:
2" and 30's
3.5" and 31's
4.5" and 33's
doghows72
I've got the WH 2.5" SL and a 1" BL tires are 32x10x17" with 4.5" BS, seems to work pretty good for me.
Welcome to the site!
