69 bronco gearing
Twistedhippie
I recently purchased a 69 bronco and in 4wd the rear end is hopping, the guy I bought it from says they put 4:10 in the front and 4:10 in the rear, it's my first ford so I'm not sure what they should be, but I know it's not right, any info would be appreciated.
67sport
Vancouver Island, Canada
4.10's were a factory offered ratio, depending on options when ordered. Whatever ratio has been installed, they need to be matched front and rear (or close, like 4.09/4.10) or you will have binding issues. Tires are all the same size?
Without knowing your eperience, even matched gearsets will cause binding if you are in 4WD on dry pavement. The surface must have some slip to engage 4wd (wet pavement at least).
While it's not any accurate way to determine your gear ratio, you could jack up the truck and rotate/count pinion rotation for one full tire rotation at each end. You could at least determine that they were the same. Maybe the PO only changed the rear gears, if it was a street only truck?
Sent from my SM-T560NU using Tapatalk
mrdrnac
Welcome to the site! One other thought has the Bronco transfer case been twin sticked? If so, make sure one isn`t in low and the other high range.
T
Twistedhippie
Thank you. All 4 tires same and only single stick tcase, I'm willing to bet they only changed the rear since it was a street truck. I will check.
