69 Bronco story and restoration
Remos69
Remos69
SW Florida
Duff bumper install finished
Washer reservoir installed and plumbed
Horn installed
Hood lift installed
Door gaskets finished
Dumped in 8 gallons of fuel
Getting a lot of help, so don't be impressed!
Remos69
Remos69
SW Florida
Hood removed to install Cowl lacing (oops! Forgot the lacing),power to passenger seat run & tested and driver's window installed (shop did all the work today,not me). Heading off to Vegas tomorrow for the weekend to watch my daughter get married.
Remos69
Remos69
SW Florida
Seats are almost finished!!! Backs and headrest still need to be done. Hopefully completed and installed this week.
Remos69
Remos69
SW Florida
Seats are back from upholstery, installing them today when it warms up a bit.
Remos69
Remos69
SW Florida
First door panel completed and installed, new top for the console. Hope to have it on the road next weekend!!
Remos69
Remos69
SW Florida
AAARRRRrrrrggggggggg!!!! The final test run before I brought my baby home went @$#_&($##+?&_$!!!! Up. Mechanic heard a very loud rattle coming from the engine bay on the return trip of a 10 mile run about 1/2 mile from the garage. He shut it off and towed it back. Worked with him t-shooting and found a bent pushrod in the #2 cylinder. Pulled the intake manifold and all looked ok, even scoped the cylinder with a camera. Put the intake back on and put in 2 new pushrods,. Did a compression test on #2 and it was a big fat goose egg!! All other cylinders were about 130psi. Called ATK and they have us pulling the engine and sending it back for replacement. So #()@__$ close!!!!! Engine had 18 miles and 2 hrs of run time tuning the fitech..
Cortez
Aaaaghh! That hurts! So frustrating when you are this close, I would have screamed out loud a few choice words. Hope it’s fixed soon for you.
sprdv1
REBEL
Never fails does it... Hang in there
HigginsHorse
I'm in the process of installing the same family cage. Yours looks great, btw. I'm currently replacing my rusted out kick panels. Would you have any pics of where the cage mounts to the floor? I'm especially interested in what you did in the rear by the tailgate.
Thanks.
HH
Remos69
Remos69
SW Florida
Higginshorse, I try to take a few pictures tomorrow of the install and mods that were done
Remos69
Remos69
SW Florida
Had a dilemma on what to do with the seatbelts after I had forgot to weld the bung into the rollbar. I came up with this idea of using split collar tub clamps drilled a hole through it and welded a heim bung then powder coated them to match the roll bar.
Remos69
Remos69
SW Florida
A couple of days late, but as promised. Mounting done installing the Tom's bronco Family Cage
Remos69
Remos69
SW Florida
Replacement engine shipping tomorrow from Texas!!!!! Hopefully driving by next weekend.......... hopefully
Remos69
Remos69
SW Florida
Finished install of the new ATK crate engine today! All cylinders have compression between 125 & 132. Drove the Bronco home and put it in the garage for the first time! Still running a little rough, but will play with the timing and fitech. Had to drive it through rush hour traffic and hit every red light to bring it home! Fitech showing temp @168, IR showing 174, gauge showing @ 210 , IR on the sensor showing 188. Oil pressure is at 60
trekgurl
nice build and bronco. Please forgive the 100 questions,,, I Like the DC rear quarters, thats a good look (and those tires). Any reason you decided to go that route? I see your in florida, are you fishing or in the dunes some? Floatation 'm thinking?,,, as those tires would seem to do better? What is your tire and wheel combo? I went with a 16in wheel on 265's, on mine, but its uncut. Thinking about this DC fender setup to get a little more usability for fishing etc. Did you play around with the location of the rear fender any? I know I hear people talking about "moving" the rear axle an 1" to compensate for fender/tire clearance and seems like one could make that adjustment with the new fender? Great looking bronco.
Remos69
Remos69
SW Florida
The Bronco fenders and quarters were cut at the dealership before my uncle brought it home so I liked the look, but when I saw the DC quarter panels I thought the look was a nice compromise between LUBR and flared. That is the only real reason I went with those. I probably won't be taking it in the dunes for a while, it is more of a cruiser right now. The wheel and tire combo is something I was definitely going after with 15 in rims and 32 tires. I was looking for a bit of a squat look. I have no lift other than a one inch body lift so I think the original axle position is fine for my use. I think if I were using it more off-road I would add a suspension lift and move the axle back as it could be a bit tight.
sprdv1
REBEL
Looks sweet....
