71 Cali Bronco Build
71 CA Bronco
71 CA Bronco
It was a tight fit but I got it.
Heads up on this one. If you go with the TBP plate cage check your door strap bolt holes before welding.%)
green61bug
Greensboro
Nice install! Turned out great... I wouldve been sweating bullets too! ... I am not the one to be working on anything restored. Haha
71 CA Bronco
71 CA Bronco
Thanks guys. Next step is the hard top. Unless I find a pristine one I think I will be going with a new one. Trying to figure that one out now.
71 CA Bronco
71 CA Bronco
The vent window does not open with the door closed but you can open the vent window while the door is open then shut the door. It hasn't been an issue for me a all.
71 CA Bronco
71 CA Bronco
Clean work! Really looking great. Love that blue!
Appreciate the kind words. Definitely a long haul.
Still looking for a nice hard top if anyone has one for sale. I tried to buy Tom's but apparently some parts are out of stock now.
71 CA Bronco
71 CA Bronco
Well I've been having so much fun driving the Bronco I haven't posted any updates. I built a TBP full top. It was a bit of work but it is completed now.
First thing you need to do is cut out the corner braces so you can get the side panels on. I don't know why they don't just use temporary braces. They were a pain to remove without damaging.
71 CA Bronco
71 CA Bronco
More pictures of the side panel and corner brace.
71 CA Bronco
71 CA Bronco
Apparently they do not make the clips that go on the drip rail, so I welded mine up.
71 CA Bronco
71 CA Bronco
Fitting the side panels. I used sidewalk bolts and panel adhesive on the seam then welded in the corners and braces. The panel bound was to keep it sealed and prevent rust which appears to be a common issue in that seam.
71 CA Bronco
71 CA Bronco
This is how I clamped and bolted it together.
71 CA Bronco
71 CA Bronco
These are the braces that were supposed to come with the kit but didn't I bought them after the fact.
71 CA Bronco
71 CA Bronco
I made a threaded plate for the backing of the liftgate hatch.
71 CA Bronco
71 CA Bronco
Test fitting here.
71 CA Bronco
71 CA Bronco
I made these braces to keep my bed square. I would have just made a tab on the roll gage but had already power coated it. Seems to have worked well.
71 CA Bronco
71 CA Bronco
Back from paint doing the liftgate hardware (that was fun) and weather stripping.
stout22
Athens, AL
Great writeup on the top! I don't think I have seen anyone document a hardtop build before.
Wrightracing
Nice Job, This is useful. I am going to be redoing my 72 top and seeing the braces you put on the top.
I have heard of an additional cross brace in the roof also, to stop the roof from flexing.
David Wright
