GubNi
I have a 71 Bronco project for sale. It's got a clear title and has all the upgrade parts from a 77 Bronco. I have checked the frame carefully and it's solid. It runs great. Asking $3500 423-737-0265
Here's what has been done:
Rebuilt 302 engine bored .30 over with aluminum intake
New Holley Truck Avenger carb
MSD ignition
New battery
rebuilt C4 automatic transmission
J shift transfer case
rebuilt front axle converted to disc brakes
big bearing rear axle from a 77 Bronco
new rear brakes
power steering
power brakes with new booster and M/C
Sandblasted and rust holes fixed
New floor boards welded in and painted on both sides
4" lift with new rear springs and adjustible tracbar
35" SuperSwamper TSL radials with 1/3 tread
Here's what needs to be done
install hardware from old doors into new doors
shim doors for alignment
fix slow leak at the rim on one tire
fix turn signal
needs painting inside and out
new stero system
dipstick tube needs to be mounted better - leaks at oil pan
Has original seats and a set of newer high back seats, but neither is installed
Overall it's a great project, but understand that it needs work. The expensive part is done. It's already lifted and has a rebuilt drivetrain. The motor and trans was rebuilt a few years ago, but they do great. I just needs your time to get it finished up.
MSD ignition
New battery
new rear brakes
power steering
fix turn signal
new stero system
