So I bought my first bronco about a month or so ago. I have been reading this forum a lot and using it as a guideline for my projects. I am still in the process of learning and seeing what the PO did as compared to how it should be done. Now my inexperience is getting the best of me and I need some help, please!! The basic low down up front of what I am working with, 1971 Bronco w/ Boss 351, 351C w/ 4barrell Holley Carbs
It started after I changed the motor mounts. I made a really rookie mistake (which I admit I am a rookie). When I lifted the engine to put the motor mounts on, I leaned the engine back on the wiring harness. I managed to crush a few wires in half, the fuel pump wire, primary wire, and the left turn signal wire. This is where the snowball effect started. Not knowing that the wires were crushed, the vehicle started and I went on home (about 4 miles). Next day drove it about 9 miles then parked it. That following day I went to drive her and it wouldn’t start.
After some peaking around I realize that that the carb is not getting any gas. I check the fuel lines and pump; the metal fuel line from the pump to carb is kinked pretty badly. I would say that it was kinked so only about 20% of the fuel was allowed to get through the line. So I just replaced the fuel pump, fuel filter, and fuel lines from the pump to the filter. This is when I noticed the crushed wiring harness, soldered and shrink wrapped them back together. Matched it up wire to wire so I didn’t cross any wires, now its time to try and fire it up. With a little started fluid to the carbs I got it cranked. It was running for about 30 seconds or so. My whole problem was not getting gas to the carbs. So I have my buddy press the pedal a little so I can look at the carb to see what its doing. From what I saw it was spraying gas in the front 2 barrels, not the back two. Then my buddy hit the gas pretty hard once to keep it alive. That’s when it backfired out of the carb and died. This is where I am stuck. Since then I haven’t been able to get it back up. From what I’ve been reading when it backfires like that it’s either the timing or a burnt valve. Now the dizzy did jump about 180*, I found TDC and pointed it back to #1 spot.
I replaced the plugs (autolites). I also found out that I blew the ignition coil accell 4180C. So I put the stock coil back on and it acted like it wanted to start. No blown fuses either. After another can of starter fluid and some hesitation from the engine I was able to get it started (ran really crappy) and then it died again. It was only staying cranked off of the starter fluid. I didn’t notice any gas being sprayed into the carbs. When I installed the fuel pump I put it in at angle and as I put the bottom nut on I had to compress the pump to get it bolted down. Is it possible I installed the fuel pump wrong? What else could be my problem?
My timing has been off since I bought it, but not bad enough to where it wouldn’t start. Just a extra turn or so when it cuts off. It was running rich, and that was with the kinked fuel line. I am thinking that since I replaced the fuel lines allowing a lot more fuel through it really threw off the timing even more. The timing issues then caused the dizzy to popped 180* off, the back fire through the carb, and the blown ignition coil. Does that sound right? What else could be broken? Thanks for reading all of this! I appreciate any help in advance!!!
