I haven't seen where anyone on here has mentioned it, or if it would be in your budget, but you can buy brand new frames for what I would consider reasonable, $2500-3000. In case you didn't know that already.
I onlu mention the hood shims because on the passenger side the hood seems to come up short to the front of the grill. my factory hood came up short on the same side new from the factory after repainting I shimmed the rear hinge to push it fluch with the grill edge. I don't mean to scare you.oh, I don't have the hood leveler things in. I usually use a blank and anything laying around to put the hood level to the fenders You scared me for a second! lol
do you have a press if so the way I would attempt it is to mak a punch and die take a piece of 3/16 steel and burn a slot in it then Take another piece of steel and cut it smaller than the slot by 1/8" all around then press the punch on the sheet metal into the slot. may have to clamp the sheet metal down so it stays flat while pressing. do small pieces and weld together instead of trying to hold one big piece. more metal to cut out of your washing machine. you will need to polish and radious the punch and die. Got any of the ribbed sheet metal left over or cut out from the floor boards?
Oh my. You are not screwing around. You about got that built in the time I had to read the updates to your build thread. And I disagree with you I think your bronco will be every bit as nice as my build and many others on here. Everyone has a different take on how to go about it. That's what's great about these old Broncos we can tweak them to our tastes. Nothing is sacred. I also had a bunch of help from others on this board.
Those raised ridges are from a bead roller. I had mine done by a local hot rod shop for $20. You might find someone local that can do that for you. You should also think about how to seal that hatch down. You won't want water getting in under the dash. The few I have seen have a rubber gasket and the hatch bolts down tight. Maybe someone can post a picture for you? You will not regret raising the cowl when you are buttoning up your AC hoses. Keep it up. Love to follow your progress.
I just read Rusty's post. I would love to see how that is done. Might be a good trick to know.
Yep like fitzy would say cut and butt. you do what you do with what you got.Hey Rusty, yes, it's a small press, but seems pretty strong. I'll look and see what I have left over. I did take a haul of old metal to the steel dump a few weeks ago, but it all was horrible. Are you thinking I could cut out the old raises and weld them on? that is If I have anything
Did your valiant have the push button automatic?
Keep up the good work!
Or the flexible driveshaft they called a Rope Drive. Carol Shelby was involved in that design the goal was a flat floor that they accomplished. Lots of things about those that were really cool and only for a couple of years.Hi, no, it was on the column. My next to oldest brother would show me how he could spin the tires by backing up really fast, then drop it into drive! That's before I got the car~ I knew that wasn't a good thing to do. However, the transmission never gave me any problems funny, I don't know what happened to the car. I inherited my grandmothers '63 Pontiac lemans hardtop with red interior, 326, rear transmission~ first thing the AC went out(I can do without that), then the transmission went out. Local transmission places didn't even know about the rear trans! lol The car sat out in the pasture until it got hauled off. That was one sharp car! sigh
