66Gasgrill
I've got a 73 for sale that I need gone. I posted a few months back and got very little intrest so here goes.
73 Bronco
302 runs and idles well but smokes a little i think it needs valve seals but I did not tear into it that far. Has a new Dizy, cap, rotor, plugs, wires, coil, fuel pump, Master cylinder, starter, and solinoind. I also rebuilt the carb.
3spd on the column shifts fine but tries to jump out of reverse
T-case and hubs work fine
D-44 9" w 3.50 opens drum brakes
I did some work on the body and then lost intrest. I replaced both front floor pans, patched the drivers side kick panel and replaced all 4 of the patch panels around the wheel wells. the tub is not in bad shape but it's not in good shape either. The doors and tail gate are pretty bad as is the lift gate. Top itself is in pretty good shape with only a small dent over the drivers front corner.
It does run drive and stop pretty well but I would recomend trailering it if you will travel very far
Perfect platform for a trail rig as is or put a little more in it and have a nice street truck.
73 Bronco
