    Discuss it more here:
ID 73 Ford Bronco 6 port manual fuel selector switch wanted
City: Boise Idaho
Looking for an operational 6 port manual fuel selector switch for a 1973 Ford bronco.
JGO
good luck with that. I broke the spool valve in mine trying to free it and ended up with a marine application close replacement. If you have one that is just bound, remove the cap/lever, use a tap to cut threads in the center of spool then you can screw a bolt in to use as a puller and it shouldnt break
M
Thank you JGO....I also broke mine. Do you have any details on that marine replacement you could share? I would be happy to go to the 3 port replacement but am unsure what to do with the 3 return lines.
Thanks again
jamesroney
Fremont, CA
Thanks again
You have to put an ampersand "@" in front of the username in order for the member to be notified. I can assure you that @JGO has no idea that you posted on your thread, unless he is subscribed...which he is most likely not.
But now that I tagged him in this thread, he will get a notification and then he will reply.
