icebreaker88
Kinda looking to see if there is any interest in my Bronco.
Not 100% sure on selling it yet. Just looking to see if there is any interest in it.
All the truck needs is the new motor installed which I have.
The truck wheeled Great, flexed great and also drove down the rode good.
As you can see the body is beat up from the rocks. Would not take too much work to make it look real nice again. I replaced almost the whole floor pan during the initial build.
I am not hurting for money just thinking of another project. Thinking around 9k I have well over 15k into this. Can be negotiable but WILL NOT take stupid low ball offers.
May also consider trades for a Harley bagger (Road king or Dresser)
The truck has less than 2k miles since the original build.
74 Bronco
Built C4 with 1 trip on it
Complete 93 5.0 less than 50k miles. I personally ran it before it was pulled
Twin stick D20 w/ Custom flat flange on rear out put
D44 W/Warn Chromos, warn lockouts, CTM's 4.88's, Disk brakes, Spooled
9" 31 spline, Superior(sp) shafts, Disk brakes, spooled
38.5" Grooved Boggers on 15x10 bead locks. 80% tread
Brand new 38.5" TSL on Aluminum 15x8 mod wheel (fullsize spare)
5.5" Deaver superflex springs front & rear
Rancho 9000x long travel shocks
Custom radius arms on front
Anti-wrap bar on rear
Hydro assist steering, 1.25" DOM steering linkage W/ 1ton TRE's
Custom front bumper
Sliders
Modified Saginaw steering pump
160 amp alt
1350 rear D-shaft
1310 Front D-shaft
Full cage tied to frame
Corbeau baja SS seats w/ 5 point harnes's
Full gauges
Flip and fold TJ rear seat
HD 3 Core rad.
HD trans cooler
Setup for Taurus fan or Mechanical fan with shroud
Durabak bedliner inside and out.
Wild horses Gorila war flares
Full soft top
Safari top
Custom 2 piece soft doors
Door inserts
Mojave heater
All lights, turn signals and brakes lights work
Original heat & Defrost also work
NO REAR BUMPER
And as of right now no Winch
I am sure I am missing some details. I also have some extras to go with this.
D20 Tcase
drives shafts
All the stuff to install a york OBA
Everything to install the new motor but fuel lines
Harness, Computer, Mass air and fuel pump.
2 inner fenders
1 fender
1 extra quart of the blue Durabak
This was the last trip I had it on and has sat in the garage ever since. Has always been stored in the garage since I have built it
This shows the most body damage the truck has.
74 Bronco
Custom front bumper
Sliders
160 amp alt
1350 rear D-shaft
1310 Front D-shaft
Full gauges
HD 3 Core rad.
HD trans cooler
Full soft top
Safari top
Door inserts
Mojave heater
NO REAR BUMPER
D20 Tcase
drives shafts
2 inner fenders
1 fender
