Silverhorse
1974 Early Bronco (More PICS Added)
Complete Restoration -$21,000 W/O MOTOR or $27,900 AS IS. (More PICS Added)
Bronco has been completely restored from the ground up:
disc brakes, power steering, fuel injection, etc.
Can email more photos and a video clip so you can hear the motor.
Engine: SEFI Fuel Injected 351W, hydraulic roller motor, Ford Motorsports SVO aluminum heads, Hedman ceramic coated headers, Ford Lightening GT-40 upper and lower intakes. Ford Explorer serpentine belt conversion, Griffin 4 core aluminum radiator. Transmission: C4 automatic with manual valve body. Transfer Case: Dana 20 J-shift. Axles: Front- Dana 44, Limited-Slip Differential, 3.54 gear ratio. Rear- Ford 9" big bearing, Trac Loc Limited-Slip Differential, 3.54 gear ratio. Power Brakes: Front disc brakes, rear drum, braided lines. Steering: Redneck Ram 78-79 Bronco steering box conversion, tie rod over knuckle conversion. Suspension: 5 1/2" Wild Horses suspension, 1" aluminum body lift. . Misc: Terra Comp Cowl Induction hood, Wild Horses Wrap Trap Traction bar, 6 point family roll cage( tig welded), Corbeau Front and rear seats (tied into roll cage), Wild Horses Family bikini top, Ididit Tilt steering column, Tuffy Deluxe stereo console. Etc.
