Ok so I just checked and I have no power to my coil when it's in the run position but I don't know about the start position cause I don't have enough hands to get That done right now. So what does that mean
If you have an early Duraspark system, the voltage to the coil is cut when the ignition module senses that the distributor is not turning. You would have to turn the key to start to get voltage. Duraspark II would have voltage with the ignition in run and the engine off but a Duraspark I would not. I am not sure which is in a '75.
Check your connections to the ignition module. Look for voltage at the coil when cranking. If there is no voltage when cranking then I would change the pickup coil. Ignition switch would be next on the list.
The pickup coil shouldn't affect whether or not there is voltage at the + side of the coil. Have you checked fuses?
Another quick test would be to run a jumper wire from the positive battery terminal to the + side of the coil. If it runs you know you have a wiring or connection issue somewhere.
I have similar documentation, however I believe the current is controlled via the green wire on the "DEC" side of the coil through the 1-second timer, and there will still be voltage on the "BAT" side of the coil w/key on.
You may be right. It puzzles me that the jumper did not work. If he is not getting power in the red wire to the coil then there is probably no power to the ECM. I'm still questioning wiring from the switch.
EW - with it switched on are you getting power thru the red wire going into the Duraspark box?
I'll have to check it out in the morning I'm at work now but it seems like if it's jumpered from the battery it shouldn't matter. Maybe I'm not understanding it right tho
Seems like it, but it has to get power to the box to start. If the box is getting power, then it gets really confusing because it should have started when the coil was jumpered. You may have a bad wire to the box or to the coil.
