76-77 aftermarket wheels...
bigpitbull
BRONCO ADDICT
Saltillo, MS
What size wheels are needed to avoid having to use a spacer... I have several sets of alcoas but I don't want to have to use a spacer... For those using a spacer does it make the front wheels stick way out?
turbotim2
____________
I think depends on what you are running for tie rods and TRO or not. Mine was stock and I had some 15" x 8" chrome wagon wheels on it that cleared with no problem.
Glass Pony
Sussex County Delaware
I'm running a 76-77 disc brake axle in mine and M/t Classic locks in 15x8 with 3-5/16" backspacing (no spacer). It looks like you can get away with up to 3-1/2" backspacing without the tie rod end knocking wheel weights off.
I don't think it would make a difference on the overall axle width if you ran a wheel with 3-1/2" bs with no spacer as opposed to the same width wheel with 4' bs and a 1/2" spacer.
But for my taste I don't like using spacers, just something else to go wrong but alot of people use them.
turbotim2
____________
What are you running for tie rods?
Glass Pony
Tire size isn't the issue (although a thinner tire would be less likely to rub the radius arm).
The problem is with 15" wheels with higher backspacing, the wheel lip where the weights would go contacts the tie rod end on a 76-77 D44.
Another way to it would be go to a 17' wheel.
BR549
huntsville
i have a 77 d44 that i would like to swap into a 67. the truck is uncut, so the problem is finding a wheel/ tire combo that works for now on the d30 then on the d44 later. 8" wheels are not ideal for a tall narrow tire and 7" wide rims are tough to find. not to mention stock 5.5 wheels leave almost no good selection of tires. it is hard not to cut a bronco if you want bigger tires.
pipermike
I have the 77 with one ton TRO set up. My 3 1/2" BS rims would not go without a spacer. I ended up using a 1/4" cheapo set of spacers. I have slot mags so I was able to go with a longer shank lug nut to gain back the thread engagement lost with the spacer. Not ideal but seams to work. I've also run the "good" style spacers in the past that bolt to the lugs but They were pretty thick and you could see a difference front to back.
bigpitbull
bigpitbull
BRONCO ADDICT
Saltillo, MS
The difference from front to back is what I want to avoid
Crawdad
I ran 15x8s with 3.5" BS with 35s years ago on my 73 and no problems with tie rod touching. Right now on my 76 I have 15x6 stock ford truck wheels with 3" BS and it is close to hitting but isn't. I suggest staying away from anything more than 3.5" BS in an aftermarket wheel. Will work better on a 16" and works really well for a 17". Go any bigger than 3.5" BS and might start rubbing on radius arms or even worse your rear tires might hit the shocks ( I bought mud grapplers on 18x9s w/ 5" BS and they hit shocks). I also run skinny 33s and my fenders are cut. Tires wider than 10.50s will give you different results compared to 12.50s or worse 14.50s!
What size tires and which rims are you looking at!
