This is amazingly helpful, thanks for all the input. I"m assuming that the standard T-style assembly you refer to is the same as the standard tie rod and drag link installed in the 66-65 models? My truck has been lifted already- I think it's a 4.5" lift, but can't be sure. Looking at the tie rod assembly, I'm fairly certain that it's equipped with the inverted Y style. I appreciate the input regarding the pitman arm, the shop I'm likely taking the truck to for this job isn't an old truck specialist in any form or fashion, so I was thinking I'd keep this simple, but now you've given me something to think about. This was the kit I was leaning towards purchasing.
http://broncograveyard.com/bronco/i-12750-steering-rod-kit-complete-1976-77.html
But if I did go with the T-style, would I want to buy this 4" pitman arm from the 66-75 days?
http://broncograveyard.com/bronco/i-12838-4-in-drop-pitman-arm-1966-75.html
Thanks again for all your time and input!
This discussion can get real involved real quick!
I have no experience with the inverted Y steering with a suspension lift. All I (think I) know is what I've read here, and that is the inverted Y doesn't play nice with a suspension lift.
It would be a big help to know exactly how much suspension lift you have. The stock suspension measured 7" from the top of the front axle tube to the bottom of the frame. Any more than that is the amount of suspension lift.
When a suspension lift is installed the steering geometry changes due to the change in angles of the drag link and track bar. If the angle of the track bar and drag link aren't correct, in relation to each other, you wind up with bumpsteer.
Here's a good link that explains the t-style steering geometry. It has pictures!!!
http://bulletproofsteering.com/geometry.html
Without knowing exactly what your current suspension setup is now, it would be impossible to know whether you need a dropped pitman arm or not. Also there are different drop pitman arms...
To keep the steering links close to the stock geometry some people do install a dropped pitman arm in conjunction with a dropped track bar bracket. Lately, and especially if you plan on off-roading your Bronco, it is has become more acceptable to install a track bar riser, on the passenger side of the front axle, rather than the dropped track bar bracket. The added length of the dropped track bar bracket creates more stress on the frame and can lead to a cracked frame. Ask me how I know...
The decisions on the proper way to modify the steering links need to be made by someone with experience. There are countless threads on this forum from people asking for advice on the proper way to change the geometry of their Broncos after a suspension lift and the resulting bumpsteer.
That being said, I'd think twice about having a shop that has no experience with older 4 wheel drive vehicles doing this work.
The link airbur posted is to a type of heavy duty steering setup commonly referred to as the Chevy 1 Ton steering, as it uses tierod ends from a 1 ton Chebby truck, and (somewhat) custom made links. This just happens to be what I have installed on my Bronco.
