76 Tailgate Repair Project
lsukevinc
Holly Springs
When I purchased my bronco last year, one of the first items I wanted to repair was the rust at the bottom of the tailgate. I ordered the repair piece from Jeff's. I knew their was a good bit of rust and bondo on the tailgate, but what I found ticket me off. On the outside of the tailgate, the previous owner riveted a piece of aluminum flashing over the rusted metal and placed bondo over the gap. My question now is where do I tie in my new steel? Has anyone replaced the entire lower section and tied it back into the flat portion (where the license plate goes?) I would appreciate any information or pictures from previous repairs.
before
after
tie into here somewhere?
L
lsukevinc
Holly Springs
any one? does anyone know if the bottom piece was welded to the flat piece (where ford is stamped in last picture) or this ridge just a design and not an actual joint?
bknbronco
North Metro, MN
you guys sure aren't the best at problem solving sometimes. I used the curved patch panel that's for sale everyware as well as a piece of flat sheetmetel to extend the patch panel. Weld and grind and body filler it and your set.
Cut out the cancer and patch it. Mine looked 10 times as bad as yours and now it looks near perfect.
L
lsukevinc
Holly Springs
I have figured it out, I was just asking if anyone had any suggestions or pictures of their work. I am slowly cutting away at the cancer. I welded in the bottom piece I bought last night.
L
lsukevinc
Holly Springs
overall the paint came out great. I guess my body work skills are not that great. I have a lip where the to patch panels are welded together, but it will have to do for now.
egom
El Paso
a little to late but the u pull it probably has an old ford pickup that has a good tailgate they are wider but everything is the same. and cutting from there and patching onto your tailgate might have been easier, especially where curves and and offsetts are present.
