Tailgate repair artists
landshark99
Montrose, Colorado
I am working on a tailgate for my 72 and found more rust (big surprise!) after I cut off the bottom to use the replace panel - the extra rust i found is on the inside bottom where there is a embossed line which I assume is for the weatherstripping and/or strength on the flat surface. I am inclined to just cut that whole section out and replace with flat stock. Anything wrong with doing it that way? i couldn't fabricate that relief in the metal again.. i could weld in a 1/3 of round stock of some sort and maybe get close but would like to avoid warping stuff if i can.
Also what is everyone using to repair the round ends where the hinge sits? Hole saw it out and hole saw a piece of flat stock and weld it in?
doghows72
Just a thought but before you weld in the replacement bottom you could braze those holes. Clean it up real good and the braze them up with that relief in the metal you shouldn't have any warping issues there. After treat the inside of the tail gate with OSPHO then weld on your lower patch panel.
As far as the sides for the hinge I actually cut a piece of pipe the same size that the pocket is capped that on the work bench and then welded that assembly into the tail gate.
Hope that helps a bit and I hope I understood you correctly. Good luck it can be done!!
Rustytruck
For the socket on each end I have read some people have used a full length of electrical conduit runnin from end to end. You may even be able to plug it with a freeze plug.
landshark99
landshark99
Montrose, Colorado
So evidently this is an early tailgate I was now told. 66/67? Any reason to try and keep it original and keep the embossing? Iam afraid once I start welding the seam near the rotten areas will blow through as it's definitely thinner but not enough to punch through with a screw driver.
Thanks for the advice on the brazing and pipe. I have also read exhaust pipe and freeze plugs work. Lots of options and ideas!
landshark99
landshark99
Montrose, Colorado
Most of the welding is done. I had a channel bent that closely resembles the rotted out embossing on the inside. Will clean it up and primer it this week and get it installed.
landshark99
landshark99
Montrose, Colorado
Well i have never tackled this kind of repair and it was worth the post asking for any other advice before I tackled it. Local Colorado Bronco enthusiasts encouraged me to replace the embossing since this is a 66/67 tailgate and kind of unique.
I will see how it cleans up, i could have made the hinge sockets a bit nicer but nobody will really see them anyway...
landshark99
landshark99
Montrose, Colorado
Got most of the grinding done. Started working on flattening the ends of the embossing. Should have done this before i welded it in but I will make it work.
landshark99
landshark99
Montrose, Colorado
a little bit of seam sealer here and there and i think its good enough for now.
The other side looks great, but its cold and crappy out right now so it will have to wait a few days for some warm weather.. then I will get it mounted up!
FRANKO289
Bronco enthusiast
Fantastic work ! I am about to do the same ... ok making out of 2 tailgates one good one !
