Thanks for the pics!
Measurements seem consistent with our 3.5" lift, or a slightly settled in 4.5" lift.
My vote is with the more popular 3.5, but it might depend on what size tires the previous owner installed. We might be able to narrow it down by the part numbers on the Rancho 9000 shocks.
Pinion does look low from this angle, so shims are called for it looks to me. Small end forward...
Pretty typical of this amount of lift in fact. As mentioned by rocknhorse earlier, the standard 6° shims would most likely to the trick.
Here are ours:
WH 1188 Tapered 6° Leaf Spring Shims Made from steel and include longer center bolts so they can be bolted to the pack. Rather than just sandwiched in-between.
The desired result is a rear pinion angle that aims up to about 1 or 1.5 degrees below the centerline of the driveshaft.
Assuming yours is still equipped with a driveshaft utilizing a double-cardan setup at the transfer case?
