I am having trouble figuring out this vibration issue. Here is a little history of the problem.
Started when i changed from 3.50 to 4.56 gears. Didn't notice vibration with 3.50 gears. Vibration is high frequency and it resonates at 60mph about every 2 seconds. RPM's are about 3k. It has a 3.5" suspension lift. Listed below is what i have done to trouble shoot.
tires are balanced (35")
driveshaft has been checked for balance
checked dana 20 output shaft for slack, its good
added 6 deg shim to correct pinion angle
u joints have been checked and are good
if i leave it in 2nd gear (c4 auto) and run it to 3k i do not feel the vibrations.
Only feel it in 3rd at 60
