- Apr 24, 2011
- 243
1977 ford bronco built by bronco owner since 1973, all the best stuff
new ford short block with aluminum heads, stock mustang cam with gt-40 intake manifold, 70mm throttle body, long tube headers with flomasters and duel rear exit exhaust
4 core brass radiator, edelbrock water pump with 7 blade fan & highway patrol hoses and fan clutch (always runs cool!) serpentine belt, 130 amp alternator
ford efi fuel injection, special anti theft system, inertia switch, duel electric fuel pumps, 23 gallon gas tank, hummer onboard air system
rebuilt original c-4 transmission, separate transmission cooler with thermostatic fan, lokar linkage floor shifter, aftermarket gauges
saginal power steering pump, reciever hitch front & rear and also plumbed for hydraulic winch, not included
new paint, fiberglass hood, carpet, mustang gt seats, roll bar with 3 point seat belts, lecara steering wheel, diamond plate trim, gas shock rear hatch
31 spline detroit locker rear, 10 x 15 aluminum slot wheels with 10 x 15 x 31 tires near new, premium warn hubs, new brakes all around, new master cylinder, dana 44 front (front disc brakes)
4900# gvw, new front springs, duffs 70/30 shocks
headlight relay with h4 lamps, new door locks, ignition lock, headlight switch, turn signal switch
milemarker 12k hydraulic winch available at $850 extra (760) 2750118
