reynard101
- Aug 19, 2006
- 1,098
1977 Ford F-150 4x4 Regular Cab, Short Bed. 460 cubic inch Ford, C6 Automatic, NP205, high pinion Dana 44 front, Ford 9" rear. Rust free. Lots of upgraded parts. Fun 4x4 vehicle. I have too many vehicles and too little time.
Late 1977 truck (same drive train as 78 and 79 Trucks and Bronco), originally had 351M.
-About a 4" lift.
-Aluminum wheels, 35 X 12.50 X 15 Goodyear MTRs
-Autofab 460 conversion motor mounts. Full steel mounts with contained poly bushing.
-Vintage Air - Air conditioner and heater
-460 Ford Engine. Big block. Edelbrock intake, Comp Cams - X4262H
-L&L headers and 460 conversion accessory brackets.
-Holley 770 Truck Avenger Carburetor
-C6 Transmission with lower 1st and 2nd gear (E40D transmission gears), rebuilt about 3 years ago with new clutches and heavy duty parts
-Autofab C6 transmission mount
-Dual Flowmaster exhaust
-Nodular Iron 3rd member rear end. Dayton Pinion support. Stock 31 spline axles.
-Detroit Locker in Ford 9" rear end. 4.11 gears
-Dana 44 high pinion front axle. This axle differs from the 78-79 trucks and Broncos. It has full axle tube to axle inner C. 78-79 had a cast portion near the end. Open front differential. Warn hubs. 4.09 gears
-1350 series "one-ton" rear driveshaft. Newer, High Angle Driveline brand driveshaft, not original.
-Mastercraft suspension seats
-GM center console / seat - storage below seat and in console (not shown in pictures)
-Deaver front coils. 4" lift. I had plans to get the Deaver rear spings but never did. The front end sits slightly higher than the rear. I have the original front lift springs that would level the truck. Or you can purchase the rear Deaver leaf springs from Bronco Graveyard and have it riding very nice.
-Looks like a rear add-a-leaf. Front sits a little higher than rear.
-Dynamat in the Interior.
-Newer interior carpet.
-Alpine CD/Stereo. 6.5" front speakers.
-40 gallon aftermarket gas tank. Heavy duty.
Some other things you should know.
-Body and paint are so-so. This was my desert 4x4 rig. No mud. There's dings on the truck.
-Leaks some oil. Rear main oil leak. Nothing terrible but it will mark a driveway.
-Title shows truck as a 1974. I don't believe this to be true - I believe a previous owner did this.
-Lap belts. Shoulder belts were removed for 6x9 speakers by previous owner.
-I currently have it registered out of Maricopa county for this year. I have passed emission testing in the past - I can verify this though a state website showing past emission results.
Thanks for looking.
-About a 4" lift.
Thanks for looking.
