77 Lower Steering Shaft Length (Remove/Stretch)
JaxLax
Jacksonville, FL
So the new yoke is too short to bridge the gap between my current double D lower steering shaft and the input on the new steering box.
Due to this issue with the yoke during my power steering box swap; I’ve now got to remove the lower steering shaft from my 77 stock, telescoping steering shaft and replace it with another stock style shaft (a little longer from TBP) to bridge the gap.
Is there an easy way to remove the lower shaft? I spoke with the guys at TBP and was informed that the shaft is essentially held in place with a bow that creates a press fit.
The options for removal were: vise grips on the double D shaft and then hammer strike. If that fails, move on to removing the whole shaft and rag joint; then using a vise and continuing the blunt force removal.
Is there a way to find the missing distance? Loosen the steering column bolts and then slide it as far down the mounting brackets? Any other options I’m not seeing? Are there double D double sided yokes to essentially use as a patch/mini extension on the shaft?
My stomach is in knots as this had to be done this weekend (it’s my DD) and if the part doesn’t get here on Saturday I’m gonna be Ubering everywhere and that’s just another expense plus the lost time to deal with the shaft.
Bronco 4 life
Yakima
Not your exact problem but when I did the 1inch body lift on my 72 I was able to slide the column down enough to make up for the gap between the box and steering shaft
thegreatjustino
Red Head Grease Monkey
Stockton, CA
The telescoping lower shaft would slide smoothly when new - that was the purpose. It would easily collapse in a front end collision for safety reasons. Over the years they seize up. Heat up the upper portion and slide the lower portion out while it's hot.
Justafordguy
It will slide in and out but like was said above, it's probably just seized up. I would take the whole thing out and clamp one end in a vice, soak it with some PB blaster and carefully hammer it off. Then clean and lube the shafts and put it back together.
Rocko1012
Remove horse shoe clip off center of shaft slide rubber boot down shaft and soak with PB blaster and use vise/visegrips to hammer shaft out. I also have a 77
