Front of truck sits lower than rear.No lift. I replaced my c bushings and the trac bar mount has cut the side of my c bushing I think my springs are tired. I have talked to several vendors and they only offer variable rate springs is this what i want or do i need to find constant rate? The meas. from top of axle tube to frame is 6in. and from what I've read this is correct. Also does ride height in the specs. mean this is the spring height under normal load (parked) my springs measure about 10 1/2 inches from top mount to cup right now.
