First up is a 79 Bronco, approx 134,000 miles.
Red w/ white top. Has not been driven this in a few years. It starts up but smokes a little. Figure it needs an oil change and new gas. Tailgate is rusted but should be an easy replacement. All glass seems to be good. Needs new dash pad. Rust spot in drivers side quarter panel rear bottom and drivers side lower corner where top meets quarter panel. Both should be easy fixes for someone who deals with metal repair.
Needs new tires. 2 tires hold air but the other 2 do not.
Could use a new battery
This also has the Warn 8274. If you don't know what that is then you probably don't know how good of a deal this will be. I really would like to keep this winch as it has been in the family for roughly 23 years. I had it serviced around 94 just because it was off an EB we were rebuilding. It has never skipped a beat. I have not used it in the last 4 years. Last I used it, it would only move in one direction using the control. Should be an easy solenoid fix.
I am looking for $1700 for the total package. I believe this is a good deal at that price.
Next is a '71 Bronco
This is a project bronco. The passenger side door, floor pan, rockers door post have been removed along with the both quarters and tailgate. Front passenger fender also removed. I should have all the replacement pieces needed except for maybe the inner fenders. Most parts were ordered from Wildhorses and the Graveyard.
Needs a good steering shaft. PO installed a Good Times van auto steering column but did not get a correct steering shaft.
Engine runs great and if I can remember how to hotwire it then I can get it running for anyone who wants to see it.
- 3 speed on the floor
- 3.5" JD lift
- No Top
- 6 point family cage is located in Hot Springs and can be brought down for the buyer
- 33" x 12.5" tires in decent condition
- I will even let the Bailie Bilt bumpers front/rear go along with it. Front has the bull bar
- white interior
- Front disc brakes
- twin stick kit included
- extra tailgate
list of replacement panels:
DS and PS kickers
DS and PS Outer Rockers
DS and PS Inner Rockers
DS and PS Door post
DS and PS Quarters
DS and PS floor pan
Looking for $4200 or best offer.
I really don't need to get rid of the '71 but I may be moving and I have 4 rides that I do not need to drag with me if at all possible.
I will work on pictures as soon as the sun is out.
- 3.5" JD lift
- No Top
- white interior
- Front disc brakes
- extra tailgate
DS and PS kickers
DS and PS Door post
DS and PS Quarters
DS and PS floor pan
