79 Bronco tilt install into a 74. Need after market steering wheel who has them?
mofoco1
Clovis, CA
I need an aftermarket steering wheel for my 79 Bronco tilt column that is going on the 74. I like the JBG Bronco wheels is there an adapter to make it work, doesn't show anything for the 78-79's. Also I would love one of those newer style steering quick releases, that will work on this too. Any help is appreciated...Mo in Clovis
gravy
Parsippany
It should use the same adapter as your 74 as long as its has dual horn circut- check the grant site- I got a nice billet wheel from them
Hozr
Rogue Valley, OR
Ive had great susccess with my NRG quick release hubs. The hub will have a standard hole pattern for the wheel you just have to adapt it to the steering shaft hub.
mofoco1
mofoco1
Clovis, CA
Eh? Hozer take off eh!
Hozer have you use the QR on a a Ford vehicle? I see these on the ricemobiles and Tuners but not so much on older US products. I am looking at this: A SHORT QUICK RELEASE 1.5"THIN STEERING WHEEL HUB ADAPTER
http://www.ebay.com/itm/ws/eBayISAPI.dll?ViewItem&item=320825209465&ssPageName=ADME:B:WNA:US:1123
Then a 6 hole steering wheel and a 79 bronco adapter probably from Grant like you described. What do you think? The 74 adapter has a very small hub lower circumference as the stock 74 column has a smaller lower cup than the 79 tilt column......Mo
mofoco1
mofoco1
Clovis, CA
FB Grant wheel and QR
FB do you have a 79 Bronco or a column off one? If so would you post a pic to see what it looks likes. Did you have to adjust the length of the column to compensate for the adapter and the QR?...Mo
fatboy
Glad to be here.
New Hampshire
I have a 78/79 tilt column that came out of an F150. I cut the auto hardware off and finished it as a standard column. I have had this column for years as I was planning on putting it on my F150 about 10 years ago, though that truck has long been down the road. So I have been sitting on it. I will be using it in my 67 build but to date I am still in the tear down phase. I bought the wheel and disconnect from my Father In Law when he sold his 79.
