I modified an old set of ALL4FUN radius arms using 2" quarter wall DOM and Balistic joints. Had the arms straight thinking the narrow frame rail and the wider axle would clear tires no problem. So I just put a relief cut 12" back and bent the arms in the press (took about 8k lbs to start moving) to make them similar shape to JD arms. My problem is I may have bent too far. With the caps snug using 7* poly C bushings the frame ends are probably 6" away from the frame mounts. If I leave the caps loose and attach the frame end I can start reaming the cap bolts down. Question is how much compliance do the poly bushings have? I'm probably asking 10-15 degrees more than they want from neutral. I am having to pull the frame ends in towards the frame rails to line up. The arms are the exact shape I was looking for, just the C's are not the ideal angle. Similar question for those who are running the 79 axle with JD arms: Do they just line up to the frame rails? Is there a specific arm for this application? Last question: Do the caps need to meet flush to be considered tight? The HD spring cups have an adjusting space on one of the bolts that would allow the caps to have a gap. Thanks all!
