86 F150 4wd 5.0 swap ?
bamabaja
The Shoals
So I bought the F150 for the NP 435, and decided to spent a little money to check engine, and tests out fine. Estate sale farm truck and had sat since farmers death. While plenty of Explorer swap info, what am I gonna run into on the F150 motor, transfer and transmission swap ? Assume crossmembers, mounts etc. if swap even feasible. Thinking of dropping in an off road build since only got $400 in truck, so if any driving time would be gravy. Thanks.
sykanr0ng
The transfer case is wider than the distance between the Bronco frame rails, that will be a big problem.
What intake and fuel system do you plan on using?
Transfer case won't fit (too wide)
EFI won't clear the hood.
Just a mid 80's flat tappet truck 302 engine. It will be a roller block, but still a flat tappet cam.
bamabaja
bamabaja
The Shoals
Thanks, folks. Knew there were reasons no real info on this particular swap. Much better choices are available. So will just enjoy my farm truck. Thanks again.
