9 inch Preload and solid spacer install
JohnJohn
Richmond
I just rebuild my 9 inch and did not like how the crush sleeve preload went. I could not get it to tighten up and when it did I went from 5 inch foot pounds to 50.
I think the yoke not sliding down was the problem more than the crush sleeve but I backed the nut off just a tad and it nailed 20 inch foot pounds. This is where it is supposed to be with new bearings (15-20) but I am worried that I need to replace the crush sleeve now because I went over.
Am I going the right direction here or should I just roll with what I have?
If I pull it, I am going to install the solid spacer with the shims. So do I just rip my new seal out then press the new bearing off the pinion, slap the solid spacer in with a shim or two then reassemble and test?
should I lay a new seal under the yoke but not pound it in until I get a good shim set up?
Is my new pinion bearing going to take being pressed on and off or am I going to need a new one?
Zillacon
Hackin Away!
-Yes replace it, what are you using to tighten or crush the sleeve? I use a breaker bar and pipe wrench to hold the yopke and just crack it a tad and check to see where I am at. It should never jump up like yours did.
-Do it right, diffs are not cheap.
-Yes but you shouldnt have to press the bearing off. Use a rubber mallet and smack the pinion thru.
-See my reply above, the outer shouldnt take that much resistace to take off.
My answers are in bold. Hope that helps. Get a new pinion nut as well when setting up the solid shims. Use the old nut and lube it up good so you dont fubar up the threads because you will be taking it on and off several times and the new nut is a top lock and should only be used once. Dont install the pinion seal when doing the solid shims until you have it nailed down and then install the seal on your final assembly. On a crush sleeve it needs to be done with seal in place.
70_Steve
Old Guy
Also, with the solid spacer, use your current crush sleeve thickness as a starting point for your spacer and shims. Also, as you tighten the nut, make sure, at least for the first couple attempts, you tighten the nut a little, then test the preload, tighten the nut a little, test the preload. I FUBARed a bearing set once by initially tightening the nut to spec with a spacer and shims that was way too small.
JohnJohn
JohnJohn
Richmond
Thanks guys. I will pull it and install the solid spacer.
So I guess If I can just knock the pinion out like I did when I rebuilt it I should not have to pull the new seal. That is good.
I used my impact before. If I use my torque wrench and a bar how do I keep the pinion from moving? I guess I will need the whole 3rd member out and an axel in a vise to do this.
70_Steve
Old Guy
The torque specs should be without the seal installed, as the seal rubbing will increase the torque reading.
I made a tool to hold the yoke. Just a piece of flatbar, with a big hole in the middle for the socket and smaller holes to match up to the holes for the u-bolts. Then welded that to a 18" or so piece of 3/4" pipe. I use that tool for removing the nut as well as being able to closely regulate the torque as I tighten the nut.
Works for the front diff yoke too.
JohnJohn
JohnJohn
Richmond
thanks guys. I was not thinking clearly on this one. I can just put it in my vise and use my torque wrench.
wish me luck.
JohnJohn
JohnJohn
Richmond
Thanks guys.
Will I need to check my backlash and patern again sense I installed it or can I just remove the pinion and replace the crush sleeve?
addicted
Broussard, Louisiana
I made this tool to hold the yoke out of 2" flat stock. Super cheap and easy.
Zillacon
Hackin Away!
Thanks guys.
In theory no, as your pinion depth is already set but you will want to check it once more one you have it all buttoned up anyways. I know I would/Do. Just takes a few minutes anyways.
