I have a 70 Bronco 302 / 3spd. The engine is tired, was removed and then dropped at some point bending the nose of the crank. I would like to keep the carb setup rather than go to EFI, and am looking for later model long blocks.
I am looking at buying a 96 5.0 out of a Bronco. I understand I would need to change the harmonic balancer and flywheel to go to the 50oz models, change the distributor gear, and sort out the the clutch z-bar mount since it won't bolt up to a 96. Are there any other gotchas I need to watch out for? Is the 96 5.0 a good candidate for this?
