Nathan43
The bronco is mostly torn down now. I'll be fixing the sheet metal over the holidays and trying to get it painted around march. That will depend on funds mind you. Just trying to plan most of it out, and at least 75% of parts are bought. Just have a few questions to get her planned out. Shes a 74 if it helps anywhere.
I'm just going to look over,paint, and reseal the engine for right now. It ran pretty good before the teardown, and believe it was rebuilt by one of the previous owners. Should I do or have anything done to it?
What about the C4? The only problem I have with it is the orings leaking at the neutral saftey switch.
What was the dash and center of grill usually painted? White or body color? I was leaning towards going with white on both but not sure. It's going back to the factory Ginger and Wimbledon White as far as everywhere else. I have hardly no original paint for except under the firewall to match.
Where were the factory locations for the voltage regulator and ignition module on a 74?
Any recommendations on a good headliner.
Last.(Pics below) I've been trying to find a bug shield/guard. A straight one if they are made(like the yellow eb below). The only ones I've found are the ones for a 73-79 truck that had a bow in the middle, Will they fit?
Also looking for the chrome rain shields that go above the door windows. Can't find a pic right now.
