AAW crimpers
67 Halfcab
For those of you who have installed the American Autowire kit, did you use the small crimpers, large crimpers, or both? I'm getting ready to install my kit and want to rent the correct crimper(s) from AAW. Thanks
Sorry I haven't had the chance to install one of those kits yet myself, but I would say that whatever you use on one type is probably good on another.
You're going to need mainly a nice set of small-ish ones, but some that have good power. Meaning good leverage. Short, un-padded handles don't cut it for me anymore.
I also now own a set of Weatherpack tools because they just come in so handy. I don't know if the AAW kit requires the end-user to make any Weatherpack final connections yourself or if they're all complete (I should know, but I don't!), but some of the others do.
And I just find them very handy to have. Many times I've simply had to re-orient existing plugs just to make the install cleaner. It wasn't required, but was a better way.
The little release tools are easy, cheap and effective. The actual crimpers are not. The cheap ones are junk in my opinion and just lead to much frustration. The ones that work well for me are the "borrowed" ratchet crimpers with the proper jaw inserts.
If you can rent those too, do it. At over 100 bucks usually, buying them is a lifetime commitment!
Good luck. Wait for others to chime in with their direct experiences though. Mine are just second-hand at best, other than with other types.
Oh, and if you don't get an answer by Monday (and you're hopefully not expecting to complete it by tomorrow anyway?) give me a call at WH and I'll pull a kit out and walk through it to see if there are any hidden gems it would help to know.
And even though their instructions are a bit unusual, have you looked there for any specific crimper information? Or do they expect you to already have all that dialed in?
67 Halfcab
67 Halfcab
Thanks for the reply DirtDonk. There aren't any weatherpack connectors in the bronco kit, but it does require some crimping of Delphi Packard Electric “F” type terminals. AAW sells and/or rents the needed crimpers. They also have a video on how to use the tools. I'll just call AAW next week and ask them directly. I was just hoping to get the staight dope from people who have installed the kit. ;)
I think you will, but being the newest of the four or five most common harnesses, there won't be as many who have already installed one. Unfortunately.
And, like anything else with our Bronco projects, there may very well be 20 members who've bought one and have read your post, but haven't installed theirs yet either!
You know how it goes. Hopefully someone who's done it will have some info.
