Added a parking brake warning light
SLOWnEASY
San Diego, Ca.
You know the saying "One thing leads to another"? This all originated with me fixing my parking brakes by replacing all the cables. https://classicbroncos.com/forums/threads/how-do-i-stop-the-parking-brake-from-doing-this.328392/
Then for some reason I couldn't stop working on Bronco stuff. Years ago I had to cut off the pedal to clear my home built roll bar. So to apply the P brake I had to step carefully on the park brake arm. To finally fix this I cut a piece of angle iron and ground it to shape. Then drilled a hole between the pedal and the arm and bolted it with a 1/4-20 bolt. I had to weld a small tab over the top of the arm so the pedal can't pivot.
Then I found Miket320's 's post about adding a grounding switch for adding a park brake warning light. Since I haven't had a P brake for 15-20 years I figured I was a prime candidate for forgetting it was engaged and driving with the P brake on. So I followed this post https://classicbroncos.com/forums/threads/brake-warning-light-emergency-brake-warning-light.263832/
Knowing that I was going to have to contort myself under the dash for an extended period of time I built a platform to lay on by using a step ladder and some wood planks. It really made it a lot more comfortable working under the dash that way.
I looked and my P brake assembly already had the holes drilled in it for adding a switch.
Bought a Dorman SW3898 $30 from Autozone and a 10 x 32 x 3/4 inch bolt to hold the switch on. I Had to use a philips head bolt because neither Home Depot or Lowes carries hex bolts that small and I just wanted to get it done. Of course I also had to tap the hole so I could thread the bolt in. But here's the switch all mounted up.
Even with my wood platform I couldn't easily get to the back of the ignition cylinder so I connected to the wire going from the warning light out to the brake proportioning valve. And now I have a functioning parking brake with a brake warning light that illuminates whether it's because of the P brake on or a pressure unbalance at the proportioning valve.
serial car restorer
Yes, I'll restore almost anything...
Western Oregon
Dang! I'd like to do this, as long as I don't need to spend time fabbing up a bracket somewhere. Unfortunately, I can't find the 2 holes already present in the new repro p-brake pedal assembly I have. I guess I'll need to table this until I have more time to build something. There's just too much far more important stuff I need to do on mine.
tasker
all knowing of nothing
NH
did this years ago on my project rig, works slick
S
SLOWnEASY
San Diego, Ca.
I guess it would depend on if your repro is build basically the same as the factory. I imagine if it doesn't have the recessed area for the switch then it might need some fabbing. For anybody wondering if theirs would be doable here's a better shot of the switch with the wire unplugged.
serial car restorer
Western Oregon
Went back out into the garage to take another look, with this much clearer picture fresh in mind. And quickly determined that the repro p-brake pedal assembly I have definitely does not have the 2 holes, and indeed appears to be a completely different stamping. I got mine on eBay, but it appears to be the same one sold by WH, Tom's and NE Classic's 'concours' replacement. And NE Classic shows a used one that also looks identical to those (and mine).
So I'm going to guess that there were (at least) 2 different assemblies used over the years, and the one that is being repopped does not have holes for a switch.
