Current setup -> PO had installed to what seems to be a 5.5" suspension lift, no body lift
Desired Setup -> 1" body lift + 2.5" or 3.5" suspension lift
I just installed a new gas tank, and need to run new fuel lines. I also want to upgrade to power disc on all 4 wheels sometime soon. I think I also want to update/upgrade the break lines at this time also.
If I am going to change my suspension eventually from a 5.5" suspension to a 1" body + 2.5-3.5" suspension, should I do that first? Basically, should I get my ride height to the correct height before doing all these lines? I'm guessing the fuel lines shouldn't be an issue, but will it be an issue with the brake lines if I change the ride height?
Hope this makes sense.
