hmgoy
I have a dana 20 connected to an aod with the advance adapter kit. I bought a J-shifter and i cant see how it fits. does this shifter no longer work because of the height change with the addapter. If not what shifter for the transfer case do i need? also if anyone else out there has dont this what other mods will i need to do . i have a 77 bronco with a 3.5 in suspension lift and a 2 inch body lift. The motor is a 302 from my 69' stang. i was told to use a calbe shifter for the tranny. I have also read that its gonna be a problem witht the throttle valve kick down lever. any help is appreciated with this set up! i used an aod out of a 1990's mustang. i had it built by huges transmissions here in phoenix. I bought this as a shell, body suspension and axels so I am starting from scratch. anyone know of a parts place other that driven auto in the phoenix ,AZ area?
