Like Blubuckaroo, I'm back to mechanical too after running a couple different electrics for a while. Like he said the gas formulations suck now, but you can make a mechanical work if you lines are run well, you have a quality mechanical pump (I've had pretty good luck with the cheapy Airtex lately), a good rebuild kit on your carb, and make sure you have a good phenolic spacer or thick carb gasket.
