EBGeek
- Nov 25, 2008
- 411
It appears my hard heater lines are rusting and causing chunks to get hung in my heater core intake. However, that issue is causing me less concern than the fact that my lines might possibly spring a leak from the weakened thinned lines.
What have others that have gone the Explorer EFI route done to replace the stock hard lines on the intake? Find a decent replacement set at the pull yard? Replace with soft lines? I initially thought it would be and easy swap to put in soft lines, but the hard lines have a small bypass that I understand is necessary for the ECT sensor on the intake.
