@Galt72 - thanks for that tip. Now that you point it out, I do see that same seat on lots of other builds. Never noticed the mounting points before, and that it also is a bit narrower. I'll check it out!
@Shimmy - thanks for your thoughts. I don't think the floorboard needs work as the PO had all rust remediated (with pics from a reputable company to prove it). The interior cab area and under the car were rhino lined after this work was done. I just went into the car so I could better describe the issue, so here goes... When I sit in the rear seat and move side to side or up and down, the seat itself flexes and creaks. That flexing and creaking can be felt by my bare feet on the floor. It's not a concerning amount, but I also don't think it's right. When I get off the seat and hold it by the "legs" that bolt through the floor, I'm able to feel a bit of play when I try to move the legs back and forth. Perhaps if I tightened the bolts, the whole issue would be solved. However, I'm worried about over tightening them as they just have washers underneath the car instead of proper backing plates.
Here are a couple of other things that will help you better understand where I'm coming from:
- The seat itself is black, and I'm planning to move to a parchment or tan interior at some point - so I'm planning ahead
- The seat was installed crooked - one side is about 1/2" closer to the tailgate than the other
- So regardless of which seat I move to (factory mounts or custom drilled holes) I'm going to have to plug weld a couple of holes and re-drill new ones
I hope all of that background helps. Thanks for listening!
