Air filter assembly parts missing
Buckeye Rob
Hurst, TX
Any ideas if I'm missing something here? I have two vacuum fittings in the pic and don't know where they should be tied in. Also wondering where I find the piece of rectangular pipe/hose that fits on the pieces in the second pic. And the round fitting on the air filter assembly, does something connect to that?
Finally, my air filter reeked of gas. I did just replace the dual tanks with a 23 gal tbp unit and the evap lines make their way to the bottle behind the drivers seat and to the canister on passenger frame rail then to air filter assembly.
Any ideas?
The first picture, the silver can. If you fly, carb heat. The white plastic thing half off the right side of that first picture is a thermostat. When cold it puts vacuum to the can and diverts air from by the exhaust manifold (get to that in a second). When warm it breaths through the blue inlet. Default at full throttle is no vacuum and the valve shifts to full cold. So you have a cold air intake under load, but at part throttle the thermostat in the air filter regulates intake temperature to about 100°F. Better vaporizes the fuel, warms up faster, generally runs better and cleaner.
Now that heated air. The black fitting should have some foil type duct work going down to the exhaust manifold. The exhaust heats up really fast and heats the air round it. There should be a little sheetmetal around the manifold to funnel the air past the manifold to warm it up.
B
Buckeye Rob
Hurst, TX
I'm hoping I picked up the right piece (pictured) to attach to the exhaust manifold then will get the metal duct hose to connect to the black piece.
Why might a po remove this?
Coming off the silver piece in my original post, shouldn't there be a vacuum hose attached to it? I see in some engine photos that it appears to go to the thermostat you mentioned. Right now one of the thermostat connections that is the larger of the two has a hose coming from the vacuum canister.
I ordered the 5 volume Ford shop manual set. Will it definitively show me what goes where?
jckkys
TBP has original air cleaners and parts. The steel strap that's missing on yours could easily be fabricated if you knew what it looked like. It's needed to bolt the air cleaner to the strut that also bolts to the exhaust manifold. The original air cleaners often show up on Ebey. Bronco Graveyard has a diagram of the air cleaner under the support heading.
