Air Shocks vs Flexy
motoman
Phoenix, AZ
I am old skool on a lot of things... but love newer technology. I was hoping someone here could explain the new style air shocks used on today's rockcrawlers.
Back in the day I am not sure why they called the air shocks "shocks". They were actually an elevation accentuating device. I would say "add a leaf" for lack of a better term. I used them on my 67 mustang, 70 Monte Carlo and 70 Duster to give it that aggressive stance.
Nowadays you see "air shocks" on these buggies flexing like crazy..... how do they level the vehicle and provide flex at the same time??? I DON'T UNDERSTAND!
br0nc0xrapt0r
Loves pickles
They are cheap too compared to coil overs and the springs that go with them! It's most commonly a 2 or 2.5 inch shock with oil and valves just like a regular shock. Only thing is you add nitrogen until you have the amount of up travel you want. More often than not though in a 16 inch travel shock it's about 3 inches of up travel and 13 of down. Hence the crazy flex.
shamu
Lucky as the day is long.
Sachse,Tx
Motoman I started off with 2.0 Fox Shox, the video shown has 2.5 Race Runners up front and 2.0 fox shox in the rear.
As of now I am running 2.5 Race Runner Nitrogen charged shocks on both axles. Fronts are 16" and rear are 18" . It is a challenge to set them up and I hope I got it right.
My rig is not desert worthy, but she is kinda fun in a rock garden, and I still need to learn more and to hear my spotter when he says "GO DRIVER"
http://www.youtube.com/watch?v=0BNeLnOXmdk&list=PLJosDEGq22mMswG_deRbl4TSMw8P_yweX
broncosbybart
Higher end mountain bike shocks use air for a spring as well. For the mtb, it works very well because the shock doesn't get worked to death and the air doesn't really see much temp increase. Air is progressive in rate, not linear like a spring.
Offroad, I have found that the air shocks like to unload easily. Meaning, that they try to fully extend without much weight on them. So, going up a hill the front end wants to raise up, going down a hill, the rear wants to raise up, and off camber is magnified as well. That said, they work great for crawling obstacles and are the least expensive of the 'fancy type' shocks. With a suck down winch applied at both ends they perform well for most types of trail riding but when setup correctly a coil over (more expensive) can't be beat.
av8rds
MAhole!
2300 mi East of Moab
I thought the air shocks did great on my buggy. They flexed great, rode great and didnt have any of the negative effects like you hear about sometimes(such as push off)
That being said I upgraded to ORI's. Essentially a dual chamber air shock that has a built in bumpstop. It also prevents some side effects like push off. I'm not versed enough to give you the whole run down but you can google them up.
I should add that I didnt set up my airs but did the ORI's. I havent wheeled them other than around the yard and the seem decent. The upper chamber sets the ride height, while the lower sets the, I guess you would call it spring rate. It also has internal oil and valving adjustments if you wish.
KyleQ
I would run an ORI Strut over an Air Shock due to the unloading affect of the air shocks - they are clever though...
br0nc0xrapt0r
Loves pickles
I have strongly considered doing a coil bucket raise in the front to lover my ride height and keep the same down travel and go 4 link rear with airshocks for dampening/support.
SC74
On my rig I originally went with coilovers (with two springs) - but ended up swapping them out for normal coil springs in my rear 4 link. Hind sight 20/20, I wish I had gone with air shocks originally and would have probably saved some headache. I know that KB6677 runs air shocks in his crawlers and likes them. His don't seem to unload too easy but I know that he and Ken M. fine tuned the gas / oil multiple times to get it right.
The one draw back to an air shock that a coil over shock does not have is that if it leaks or breaks there is nothing there to support the weight of the vehicle.
I gave up researching coilover springs etc. The more I read, the more I got confused. As soon as I thought I got a grip on it, I would get proven wrong.
br0nc0xrapt0r
Loves pickles
I'm Pretty se that if I do it that it's be air shock rear and coil front. Only reason is that it's still my DD and I don't need any more body roll than I already have. I think that sway bars would be a must for any sort of on road driving.
kb6677
The "tuning" is not too bad once you get over the pulling apart a perfectly good air shock and dumping the oil out!!! Measure what you have as a baseline and then start adding to "stiffen them up"We got an incredible range on "cc's to add" to increase the first time we tried it by talking to folks- On my Ranger truggy, we were dealing with the above mentioned issues of unload and ended up having to add oil to the front (2.5s) and rear (2.0s).
There is a trail at Windrock some will know called Rail trail-you drop down a long section off the gravel road and I literally had to gas my ranger the first time we ran it to keep the back from coming over the front. It was steep (112"wb)! Not something I want to experience again!!!
We added some nitrogen to all 4 this weekend getting ready for a club run in march. I am also retiring the Krawlers after more years than I thought they would ever last. Going to a true 40 so I needed a little more ride height to clear them and so more travel will be appreciated by my back and butt!
Yeller
Rogers County Oklahoma
I've set up and used them all, for simplicity I like the ORI's they are the easiest to set up. All the 2 and 2-1/2 air shocks I've used don't ride as well as the ORI's and can have handling quirks but are great in a crawler, as long as its light enough, needs to be under 2500# of unsprung weight IMHO. On my Rokit buggy I have coils and 2" air shocks in the rear, its kind of the best of both all worlds, ride is nice, stability is off the charts. I just use the air shock as a shock, but with them full of oil when compressed I get an air bump as well. Now not a desert set up but it works, for going fast can't beat a coil over and bypass shocks but that is a whole other world.
