Amen hydrboost brothers!
ken75ranger
Troy, NY
I have seen the light and tasted the windshield! ;D I had some clearence issues with my taller valve covers but it's in and works fine. Anyone with valve cover issues can make extensions to come off the firewall and up an inch with some 1x2 rectangular tube.
Special thanks to Tofic and ToddAZfor all the info in my searches.
Cost was pretty cheap.
$15 Astro booster at pick and pull
$22 camaro M/C
$44 for hoses
$20 for hardware and fluilds.
72Sport
Looks good. Those $44 hoses really make for an uncluttered look ;D.
ken75ranger
ken75ranger
Troy, NY
That's how I get hoses cheap! ;D So the picture is before I was done installing everything.
ken75ranger
ken75ranger
Troy, NY
Ok wise guys! ;D Here's a pic with the hoses.
kbronco
Are you able to get your valve cover off without taking the hydroboost out? Also can we get a close up of the firewall mount.
SurfCityEB66
x2.... could you also share what year vehicles on the camaro and astro?;D
ken75ranger
ken75ranger
Troy, NY
I can't get the valve cover off but my lines have enough slack to remove the booster off the mount and then I can get the valve cover off.
This might be a better shot. The black square on the firewall is just a piece of vinyl to keep the air out.
ken75ranger
ken75ranger
Troy, NY
The MC was for a 1980 camaro v-8 with power brakes. ( nice look on the autozone guy's face when I said -Sure it will work. Here' I'll show you.);)
The booster I just walked around a u-pull it yard until I found one with a straight mount.
I welded a coupler nut to the h-boost rod and threaded the original bronco rod to connect them.
ken75ranger
ken75ranger
Troy, NY
screamin reel said:
Don't want to hijack but why can't the MC from the Astro be used ?
I think you can.?:? I might be a height issue though. The astro M/C is pretty tall.
Banjer Picker
Are the mounting bolts turned around?
I cant really tell on my computer screen, but are the bolts turned around so that the nuts go on from the engine compartment. THat sure would be alot easier than the way I way I was fishing aroung my steering column etc. under the dash on mine this weekend.
Dave St
Roanoke, VA
You can use the Astro M/C and proportioning valve. I first did just the hydro and M/C, then several months later added the prop valve; it was woryh the extra time, made be good brakes even better! If you do it, just make sure you get the lines between the MC and prop valve as well as the fittings on the underside of the prop valve. They are some kind of metric fitting that I couldn't find, so I re-used the old fittings on new lines.
ken75ranger
ken75ranger
Troy, NY
My nuts for the bracket to the firewall are under the dash. The nuts for the bracket to the booster are toward the front of the motor. I can't see why you couldn't do it the way your thinking though.
toddz69
$22 camaro M/C
$44 for hoses
Good to see another person has accepted the gospel and joined the flock. Keep the faith and spread the word!
Todd Z.
