I'm installing a hydroboost brake system today, and I'm heading to an Aeroquip dealer for new high pressure hoses and swivel fittings.
1) Should I replace the soft line that goes from the proportioning valve to to the fitting that sits on top of dana housing as well as the soft lines that run to the calipers in front and drums in back? If so with what type of lines
2) The advise I was given from the supplier of the hydroboost system (JBG) is to bypass the proportioning valve on the front disc side ie. run a line directly from the master cylinder to the T-fitting that sits on top of the dana houseing. Does this sound rite?
Thank you in advance for your advise
