lasadoor, no i don't have a thread about it. i took the carb off to rebuild it and life got in the way so it sat for about 2 weeks without driving. once i finished rebuilding it i put the carb on and click-click-click. battery only has 9.something volts. no big deal, just need to recharge it or upgrade to an odessey!
sorry for the hijack!! back to OT:
greasypigeon, you'd have to make sure the cd player can safely be played on its side. some can play at odd angles, others are very unhappy at odd angles. i don't think you could find an ammo can wide enough to lay flat. anyways, if you can get one that plays on its side, you could then cut out the front of the ammo can so that just the face of the player sticks out. inside the can, build some sort of housing to anchor the player. maybe a little rubber insulation so it won't get too jarred. then to lock it, get a hasp and weld half of it on the lid, and half of it to the can. get yourself a small padlock or key lock, and you're good to go!
