Amp Research module mount
Green_Bastard
Hey guys, hoping someone has an idea to help me out. I'm working on installing a set of Amp Research steps and I'm trying to figure out a clean way to mount the control module. The back of the module has what looks like a mount provision but I've called and they don't offer anything. Seems a bit weird they would have this in the design without offering a bracket. Anyway, I know I've seen this design used before with a bracket but I can't remember where. Has anyone else seen this and remember the application?
ratbilt
I mounted mine with velcro (Lowes has industrial) the wires are also loomed near module so if the velcro failed the module isn't going anywhere.
I had to remove it a couple of times (sticks good) Rich
TNcowboy
I mounted mine under the battery...so it's out of sight....with zip ties which is how I guess they intended since there are raised notches on the side. It works but it's not a well thought out design
It is one design flaw that it suffers from.
betzgb
I mounted mine on the driver side firewall. I took a small metal plate and drilled 3 pairs of holes for the zips ties then screwed the plate to the firewall. Then zip tied the control module to the plate. Seemed to work out good.
