provoflyfisher
- Sep 27, 2007
- 21
Hello,
I need some serious electrical help. I have searched prior posts and tried most things, but still need some advice.
The good - 1971 all stock bronco with new voltage regulator, battery, alternator, battery cables, starter, solenoid, ignition switch and clean grounds from battery to engine block, block to frame, and block to fender. Bronco was running fine then it sat for a few weeks while I got around to repacking the front wheel bearing. Started right up after sitting for this time and ran for 4 or 5 days perfectly.
The bad - Tried to start it up in the morning and a slow turn over, sounding like a dying/dead battery (no clicking just would not fire up after 2-3 seconds). Put the battery on the charger overnight and the same result. Put in another battery and voltage regulator and same thing. Checked voltage on batteries 12.5V, checked VR at FSAI with key off 12.5V (at A) no volts at F,S, or I. Key on still 12.5V at A, and 12.5 at S with 11V at F, 0V at I.
With key off or on battery cables are cool to the touch, but after I try to start it, I noticed both positive and negative cables heat up, as does the alternator case?
The ugly - I have had electrical issues off and on for 3 years, I thought it was fixed with the grounding network to various locations. Seems to work for a couple of months then back to square one.
I have checked for drains on the system with a light between the battery post and cable and there does not appear to be a drain. Noticed some rusting/corrosion on the VR at A terminal, small break on the inner fender may be letting in water when driving? I cleaned up the contacts and sealed this off to prevent future water coming in contact with the VR and harness.
I have not tried to jump the bronco from another car, but could try?
Any help will be greatly appreciated.
Thanks,
Burt
Thanks,
Burt
