another efi fuel return question
marty
massapequa, n.y.
ok so instead of going on another thread and trying to answer this question i started another thread because this could be a simple answer. i am a marine mechanic by trade and in my business the efi engines use a no return line to the tank system. what they do is the use a spin on water seperating filter that house 2 in ports and 2 out ports. it is plumbed using one out port to the high pressure and 2 in ports one being the return line. now these are all G.M. style engines and i was wondering if i could plumb the system the same way and avoid having to run a return line to the tanks. do you see any problems doing this with maybe vapor lock. how high is the pressure on the return side.
Broncoward
Rolesville
Return line pressure is low 3 PSI?(check me!) ...With that said a simple low pressure hose is almost TOO easy to run to the tank....I say that because If I can run it I know you and any one you know could. :-[
So it sound to me that the system you want maybe more complicated that you need or desire. This is just my 2 cents so I don't want to stiffle your initiative. Does that make sense?
Respectfully
Broncoward
M
marty
massapequa, n.y.
my filter setup is very simple you need to have a filter before the high pressure pump anyway so you use this filter housing which is a nice simple bolt on piece and then you just plumb the return right back to it. just a simple loop. tank, inline filter, low pressure pump,this spin-on filter, high pressure pump, injectors and return to the spin-on. the high pressure pump can be mounted with the spin-on right in the engine bay so no need to run a long return line under the truck.
KyleQ
My car is returnless as well - but as other have said, the simplicity of running a line down the relatively straight frame is very easy.
Rollin
Port Angeles, WA
I was thinking of doing the same thing to our EFI setup too. We have a 2001 EFI Mercruiser that's a 7.4L and the return line from it goes into the fuel filter/water separator and it sure seems like it would work on the 5.0L setup.
M
marty
massapequa, n.y.
yes i feel this would be so much easier and less lines running down the rail. and you have a nice filter setup to boot. i will try to post a picture of the filter so some can understand the setup.
Rollin
Port Angeles, WA
The only reason I can think of that might not let this work though is , the marine engine burns way more gas then the car engine and what if the fuel filter is always full and there is no where for the return fuel to go and backs back up the line then what???
trailpsycho
Even BCB's accumulator filter uses a return line. Maybe in the marine applications you are using enough gas or the pumps are more synched or the computer adjusts the rate the pumps flow depending on need. In the 5.0 system most of us are running (with 2 pumps), the LP pump is supposed to flow more fuel than the system needs, the HP pump amps it for the fuel rails. Without a return, I would worry that there would be too much back pressure and that the pumps would wear prematurely or overheat...
I would/ did plumb the return line....I am using no accumulator (although I have one...its just too damn big to find a safe mounting point)....just the two pumps; I have about 9300 miles on it in the last 10-11 months...no problems.
M
marty
massapequa, n.y.
just keep in mind that a good amount of these engines in the boats are used for trolling too. so idle speed for a length of time.
